Time series analysis methods
What is time series analysis?
Time series analysis is the collection of data at specific intervals over a time period, with the purpose of identifying trend, seasonality, and residuals to aid in the forecasting of a future event. Time series analysis involves inferring what has happened to a series of data points in the past and attempting to predict future values.
Analyzing time series data allows extracting meaningful statistics and other characteristics of the data. As the name suggests, time series data is a collection of observations that themselves have been created through repeating measurements over time. Once you have that information, you can plot it on a graph and learn more about exactly what it is that you're tracking.
A very straightforward time series analysis example might be the rise and fall of the temperature over the course of a day. By tracking the specific temperature outside at hourly intervals, and by doing so for 24 hours, you have a complete picture of the rise and fall of the temperature in your area. Then, if you know that the next day is going to be relatively similar in terms of things like precipitation and humidity, you can make a more educated guess about what the temperature may be at specific times. This is an oversimplified example, yes - but the underlying structure is the same regardless of what it is that you're talking about.
Such analysis requires that the pattern of observed time series data is identified. Once the pattern is established, it can be interpreted, integrated with other data, and used for forecasting (which is fundamental for machine learning). Machine learning is a type of artificial intelligence that allows computer programs to actually "learn" and become "smarter" over time, all without being explicitly programmed to do so.
Importance of time series analysis
As more connected devices are implemented and data is expected to be collected and processed in real-time, the ability to handle time series data has become increasingly significant. This is going to become especially important over the next few years, as the Internet of Things begins to play a more common role in all of our lives.
At its core, the Internet of Things is a term used to describe a network of literally billions of devices that are all connected together, both creating and sharing data at all times. In a personal context, we've already seen this begin to play out in "smart" homes across America. Your thermostat knows that when it gets to a certain temperature, it needs to lower the shades in a room to help control the temperature. Or your smart home hub knows that as soon as the last person leaves the house, it is to lock all the doors and turn all the lights off. It wouldn't be able to get to this point were it not for an interconnected network of sensors that are sharing information with one another at all times - making time series analysis all the more important.
Among other things, time series analysis can be used to effectively:
  • Illustrate that data points taken over time may have some sort of internal structure. There may be a trend or pattern to your data that likely otherwise would have gone undiscovered.
  • Provide users with a better understanding of the past, thus putting them in a position to better predict the future.
That last point is particularly important, and it's a big part of the reason why time series analysis is used in economics, statistics and in similar fields. If you know historical data for a particular stock, for example, and you know how it has traditionally performed given certain world events, you can better predict the price when similar events occur in the future. If you know that the event itself is about to happen (like a larger economic downturn), you can use that insight to make a better and more informed decision about whether to purchase the stock itself.
Since the analysis is based on data plotted against time, the first step is to plot the data and observe any patterns that might occur over time.
Programming languages used for analyzing time series
Among the many programming languages used for time series analysis and data science are:
Flux, developed by InfluxData, is one of the newest open source programming languages purpose-built for time series analysis. A data scripting and query language, Flux makes it easy to see change across time. Traditionally, grouping, shaping, and performing mathematical operations across large dynamic time series datasets is cumbersome. Flux makes working with these datasets much more elegant.
Flux is a powerful language for working with data and is available on top of InfluxData’s time series platform. It is unlocking exciting new time series use cases and allowing developers to work with data where it resides both within InfluxDB and other data sources such as MySQL, Google Bigtable, MariaDB, and Postgres. The InfluxData platform does the heavy lifting of collecting data, storing it, and providing computing power to analyze the data so software builders can focus on implementing solutions.
Flux makes it easy to create and share a dashboard. Flux is meant to empower every query and visualization tool so that they may bring together related data sets to generate insights using a common, powerful and unified language. Providing a tool to flexibly merge together data sources and analyze them across time is one of Flux’s primary use cases.
Dashboard InfluxDB Flux time series data
Time series analysis example using InfluxDB
To build a real-time risk monitoring system, Robinhood (a pioneer of commission-free investing) chose InfluxDB (an open source time series database) and Faust (an open source Python stream processing library). The architecture behind their system involves both time series anomaly detection (InfluxDB) and real-time stream processing (Faust/Kafka).
An example of infrastructure telemetry, collected with InfluxDB by Robinhood.
Robinhood alerted on the data with Faust, a real-time Python Library for Kafka Streams.
The aggregated data (yellow) is bounded by upper and lower limits (blue).
As the number of time series grows, the effort required to understand or detect anomalies in a time series becomes very costly. This is where an anomaly detection system can intelligently alert one when something doesn't go very well.
The first anomaly detection solution that Robinhood tried was threshold-based alerting, by which an alert is triggered whenever the underlying data is over or under the threshold. Threshold-based alerting works well with very simple time series but fails to account for more complex time series. As shown below, the time series here has a trend. It's trending upwards, and there are some up-and-down patterns within that upward trend. If the fixed threshold is used to alert on anomalies, it doesn't work well because it will go over the threshold, and will trigger an alert but will then drop down a threshold and go over a threshold again. So threshold-based alerting in the case of complex time series would require the same effort as checking the dashboard 24/7.
Threshold-based alerting works well with time series but fails to account for seasonality and trend.
To fix this problem, Robinhood alerted on data outside of three standard deviations. Defining your threshold from a standard deviation for anomaly detection is advantageous because it can help you detect anomalies on data that is non-stationary (like the example above). In other words, the threshold defined by a standard deviation will follow your data’s trend. Robinhood defined an anomaly as anything outside of three standard deviations away from the mean — so 99.7% of the data lies within this range.
Data with normal distribution
An example of data with a normal distribution. Data that is outside of three standard deviations away from the mean (shaded with green lines) accounts for only 0.03% of all of the data.
Applications in various domains
Time series models are used to:
  • Gain an understanding of the underlying forces and structure that produced the observed data.
  • Fit a model and proceed to forecasting, monitoring or feedback and feedforward control.
Applications span sectors such as:
  • Budgetary analysis
  • Census analysis
  • Economic forecasting
  • Inventory studies
  • Process and quality control
  • Sales forecasting
  • Stock market analysis
  • Utility studies
  • Workload projections
  • Yield projections
Understanding data stationarity
Stationarity is an important concept in time series analysis. Many useful analytical tools and statistical tests and models rely on stationarity to perform forecasting. For many cases involving time series, it’s sometimes necessary to determine if the data was generated by a stationary process, resulting in stationary time series data. Conversely, sometimes it’s useful to transform a non-stationary process into a stationary process in order to apply specific forecasting functions to it. A common method of stationarizing a time series is through a process called differencing, which can be used to remove any trend in the series which is not of interest.
Stationarity in a time series is defined by a constant mean, variance, and autocorrelation. While there are several ways in which a series can be non-stationary (for instance, an increasing variance over time), a series can only be stationary in one way (when all these properties do not change over time).
Patterns that may be present within time series data
The variation or movement in a series can be understood through the following three components: trend, seasonality, and residuals. The first two components represent systematic types of time series variability. The third represents statistical noise (analogous to the error terms included in various types of statistical models). To visually explore a series, time series are often formally partitioned into each of these three components through a procedure referred to as time series decomposition, in which a time series is decomposed into its constituent components.
Trend
Trend refers to any systematic change in the level of a series — i.e., its long-term direction. Both the direction and slope (rate of change) of a trend may remain constant or change throughout the course of the series.
Seasonality
Unlike the trend component, the seasonal component of a series is a repeating pattern of increase and decrease in the series that occurs consistently throughout its duration. Seasonality is commonly thought of as a cyclical or repeating pattern within a seasonal period of one year with seasonal or monthly seasons. However, seasons aren’t confined to that time scale — seasons can exist in the nanosecond range as well.
Residuals
Residuals constitute what's left after you remove the seasonality and trend from the data.
Methods of analyzing time series data
Time series analysis methods may be divided into two classes:
  • Frequency-domain methods (these include spectral analysis and wavelet analysis)
    In electronics, control systems engineering, and statistics, the frequency domain refers to the analysis of mathematical functions or signals with respect to frequency, rather than time.
  • Time-domain methods (these include autocorrelation and cross-correlation analysis)
    Time domain refers to the analysis of mathematical functions, physical signals or time series of economic or environmental data, with respect to time. (In the time domain, correlation and analysis can be made in a filter-like manner using scaled correlation, thereby mitigating the need to operate in the frequency domain.)
Additionally, time series analysis methods may be divided into two other types:
  • Parametric: The parametric approaches assume that the underlying stationary stochastic process has a certain structure which can be described using a small number of parameters (for example, using an autoregressive or moving average model). In these approaches, the task is to estimate the parameters of the model that describes the stochastic process.
  • Non-parametric: By contrast, non-parametric approaches explicitly estimate the covariance or the spectrum of the process without assuming that the process has any particular structure.
Below is an overview of each of the above-mentioned methods.
Spectral analysis
Many time series show periodic behavior that can be very complex. Spectral analysis is a technique that allows us to discover underlying periodicities — it is one of the most widely used methods for data analysis in geophysics, oceanography, atmospheric science, astronomy, engineering, and other fields.
The spectral density can be estimated using an object known as a periodogram, which is the squared correlation between our time series and sine/cosine waves at the different frequencies spanned by the series. To perform spectral analysis, the data must first be transformed from time domain to frequency domain.
Learn more about spectral analysis.
Wavelet analysis
What is a Wavelet? A wavelet is a function that is localized in time and frequency, generally with a zero mean. It is also a tool for decomposing a signal by location and frequency. Consider the Fourier transform: A signal is only decomposed into its frequency components.
Wavelets are analysis tools mainly for time series analysis and image analysis (not covered here). As a subject, wavelets are relatively new (1983 to present) and synthesize many new/old ideas.
Autocorrelation
What is autocorrelation in time series data? Autocorrelation is a type of serial dependence. Specifically, autocorrelation is when a time series is linearly related to a lagged version of itself. When you have a series of numbers where values can be predicted based on preceding values in the series, the series is said to exhibit autocorrelation. By contrast, correlation is simply when two independent variables are linearly related.
Here’s why autocorrelation matters. Often, one of the first steps in any data analysis is performing regression analysis. However, one of the assumptions of regression analysis is that the data has no autocorrelation. This can be frustrating because if you try to do a regression analysis on data with autocorrelation, then your analysis will be misleading.
Additionally, some time series forecasting methods (specifically regression modeling) rely on the assumption that there isn’t any autocorrelation in the residuals (the difference between the fitted model and the data). People often use the residuals to assess whether their model is a good fit while ignoring that assumption that the residuals have no autocorrelation (or that the errors are independent and identically distributed or i.i.d). This mistake can mislead people into believing that their model is a good fit when in fact it isn’t.
Finally, perhaps the most compelling aspect of autocorrelation analysis is how it can help us uncover hidden patterns in our data and help us select the correct forecasting methods. Specifically, we can use it to help identify seasonality and trend in time series data. Additionally, analyzing the autocorrelation function (ACF) and partial autocorrelation function (PACF) in conjunction is necessary for selecting the appropriate ARIMA model for your time series prediction. Learn how to determine if your time series data has autocorrelation.
Cross-correlation
Cross correlation is a measurement that tracks the movements of two variables or sets of data relative to each other. In its simplest version, it can be described in terms of an independent variable, X, and two dependent variables, Y and Z. If independent variable X influences variable Y and the two are positively correlated, then as the value of X rises so will the value of Y.
If the same is true of the relationship between X and Z, then as the value of X rises, so will the value of Z. Variables Y and Z can be said to be cross correlated because their behavior is positively correlated as a result of each of their individual relationships to variable X.
Parametric vs. nonparametric tests
Parametric tests assume underlying statistical distributions in the data. Therefore, several conditions of validity must be met so that the result of a parametric test is reliable. Nonparametric tests are more robust than parametric tests. They are valid in a broader range of situations (fewer conditions of validity).
Nonparametric tests do not rely on any distribution. They can thus be applied even if parametric conditions of validity are not met. Parametric tests will have more statistical power than nonparametric tests. A parametric test is more able to lead to a rejection of H0. Most of the time, the p-value associated to a parametric test will be lower than the p-value associated to a nonparametric equivalent that is run on the same data.
Time series models
Generally speaking, there are three core models that you will be working with when performing time series analysis: autoregressive models, integrated models and moving average models.
An autoregressive model is one that is used to represent a type of random process. It is most commonly used to perform time series analysis in the context of economics, nature and more. Moving-average models are commonly used to model univariate time series, as the way the output variable is presented depends linearly on both the current and past values of an imperfectly predictable term. A traditional integrated model is one that lists all data points in time order.
How to do time series analysis will obviously vary depending on the model you choose to work with.
Time series analysis best practices
For the best results in terms of time analysis, it's important to gain a better understanding of exactly what you're trying to do in the first place. Remember that in a time series, the independent variable is often time itself and you're typically using it to try to predict what the future might hold.
To get to that point, you have to understand whether or not time is stationary, if there is seasonality, and if the variable is autocorrelated.
Autocorrelation is defined as the similarity of observations as a function of the amount of time that passes between them. Seasonality takes a look at specific, periodic fluctuations. If a time series is stationary, its own statistical properties do not change over time. To put it another way, the time series has a constant mean and variance regardless of what is happening with the independent variable of time itself. These are all questions that you should be answering prior to the performance of time series analysis.
Scroll to Top
